- 8 Sep 2008
- Birmingham
Hey everyone. Im fairly new to overclocking. My first and current system was purchased last October from overclockers and came pre-overclocked (system spec: [email protected] GHz, artic 7 freezer cpu cooler, 4GB corsair dominator 1007Mhz, 500GB 7,200rpm Seagate barracuda (used to run vista x64 ultimate os), 7,200rpm 1TB Samsung spinpoint (750GB storage, 250GB partition with windows 7 RC), corsair 650W power supply, abit quadGT motherboard, Gainward GTX280 1GB, antec 1200 case)
I recently had to return this to overclockers.uk as there was a powersupply fault which resulted in the loss of the overclock. When i got my machine back they had redone the overclock but I noticed the temperatures were idling at 45 degrees whereas the pre-return overclock was idling at 35 degrees. A 10 degree difference was pretty huge in my opinion.
Looking at the voltage I could see why. 1.47V for a 3.02Ghz overclock seemed a bit high so after some research I read that if I changed my FSB:RAM ratio to 1.1.0 and changed the FSB to 333 MHz I could roughly get the same speed (3.00Ghz) with standard voltage.
So now my system is running at 1.32V, 3.0GHz CPU, 1000MHz RAM speed and it seems faster and more stable then the overclockers “professional” attempt. Tested it for 30 mins with prime95 and with everest ultimate ver 4.6 stability test with no issues (plays fallout 3 and dawn of war 2 flawlessly and with high fps)
I have 2 questions for anyone who would be kind enough to answer them
1) I just wanted to know if by leaving intel speedstep enabled (the voltage changes frequently 1.19v-1.32v at x6 and x9 multipliers respectively (as measured using everest ultimate sidebar). Will this have a negative effect on my current setup? (I just wanted to save some electricity and unnecessary heat)
2) If I installed another 4GB of RAM onto the abit quad GT mobo would that affect the current overclock I have set on the machine or have any other negative impacts on the system?
Thanks in advance
Thanks in advance
so i cleared cmos and went for something more realistic. I got the clock up to 3.2 GHz but it failed prime 95 (on only one of the cores). Dropped it to 3.1 GHz but same prime 95 error occured. Looks like 3.0 GHz is the highest stable speed im gonna get from stock voltages, im quite happy with that unless anyone has any ideas how to get a faster speed? (CPU voltage from everest says 1.32-1.33 without speedstep enabled)
