resizing a logo without distorting?
smr
smr
6 Mar 2008
Leicestershire
Hi,
I want to design a logo which will be resized from something as small as business card size to a car sign size without distorting the image when resized, and then resizing for various different sizes. I am using Adobe Photoshop CS3. How can I do this?
Do it as a vector in Adobe Illustrator. That's by far the best option. Photoshop has some vector support but it's quite limited.
You can't simply upscale a bitmap without it losing quality, you'll need to recreate the logo as a vector, plenty of free editors about, try inkscape.
I'm downloading the trial of Illustrator CS4... Never used this sw before so I'll see how I get on with this first... but yeah, that's basically what I want to do... design the logo once, and be able to resize it for various different dimensions ranging from business card size to a much larger car magnet sized logo.
Personally I'd agree with Cuchulain, Inkscape is a great vector program and so simple to use.
It's always wisest to design a logo in a vector application like Illustrator or InkScape unless you're only going to use the logo on the web. A vector format gives you unlimited flexibility when it comes to scaling.
InkScape is quite good and very easy to use, but I don't think the results always look as professional as Illustrator's.
