*** Amazing Zotac GeForce GTS 250 AMP! Edition 1024MB GDDR3 @ £108.99 ***
Suspended
18 Oct 2002
OcUK HQ
*** *** Amazing Zotac GeForce GTS 250 AMP! Edition 1024MB GDDR3 @ £108.99 *** ***
Supercharge your gaming experience with the Zotac GeForce GTS 250 AMP! Edition, tuned and tweaked with higher engine, memory and shader clock speeds for unprecedented gaming performance. Powered by high-speed GDDR3 video memory, the Zotac GeForce GTS 250 AMP! Edition delivers unmatched performance and value. NVIDIA PhysX technology takes the Zotac GeForce GTS 250 AMP! Edition beyond 3D gaming with graphics plus capabilities. PhysX technology enables the Zotac GeForce GTS 250 AMP! Edition to calculate realistic physics in real-time for realistic environmental interaction and effects for an immersive gaming experience that blurs the line between reality and the virtual world.
- Core Clock: 750MHz
- Memory: 1024MB GDDR3
- Memory Clock: 2300MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 128
- Shader Clock: 1890MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2 Dual-Link DVI-I
- SLI Ready
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 5 Years
Just £108.99 Inc. VAT
BUY NOW
Hahaha :D
I know what you mean, although I'm done with Nv for a while, until they sort out all the renaming BS.
Sad thing is I actually know a guy that went from a 8800GTS to a GTS 250 thinking it was just behind a 260 :(
how much better are these then my 8800gtx
very small difference. At higher resolutions I'd imagine your 8800gtx would perform better due to more memory bandwidth.
I dont think it would be worth the upgrade. Certainly not for £108.
the 1gb 4870 would be a better upgrade although for a real jump a 4890 or 275 would be more worthwhile
