Nope, one or the other. That isnt to say there are 2 different versions of the same card out there. But only one set of connectors per card. The pins are different sizes and a different position on the card. It may have a PCI daughter card?
Has nobody checked the link i used above, clearly shows a card with both PCI-e and AGP interfaces
there's only pins on one side.
Actually you know i do seem to reaall a card that had a PCI-E connector on one edge and an AGP connector on the other - can remember what card it was mind
Edit :
http://images.dailytech.com/nimage/1749_large_HIS_2.jpg
