Network Adapter Card Vs. On-Board?
3 Dec 2004
Hi all,
Is there any benefit of using a Network adapter card for Internet connectivity over on-board?
I personally doubt there is (have not compared the 2), but what do you think?
Thanks,
I have an on board Enet and 2 network adapter cards, each 1 running a 20mb cable modem (x3 total) using wingate to link them up. I havnt noticed any speed differences between onboard and an adapter, they just take more room...
Thanks for reply,
I thought the speed might be near or exactly the same (download). The only thing I thought might be better with the card is that it takes some strain off the motherboard resources?
I think it would only strain the system if it was a 1.6ghz celeron or such and even then i dont think it'd be a lot, maybe im wrong but on a dual core id suspect theres no difference, unless you spend about £70 for them 'low latency gaming lan cards' which i think are a complete waste of money.
I replaced my OnBoard NIC with an Intel PRO/1000 PCI-E card and its much faster at gigabit speeds. I also replaced the one in my WHS server system with the same card too. When they connect I get around 60-65mb/s between them instead of the 12-18mb/s i was getting. Which card it was I don't know, I just know I will be keeping the network cards when I eventually upgrade from my E6600 system.
For 10/100, no point. For decent gigabit links, you'll need an Intel like above.
