Worth the upgrade?
8 Apr 2008
Bratfud
Hi guys
I have a bit of money left from my birthday and I was thinking of upgrading my current CPU/MB to a Phenom II 720 and a Gigabyte GA-MA770-UD3.
Would it be worth the upgrade or would i be better getting say a better GFX card?
Wardyp.
I mainly use it for gaming, TF2, L4D, DOW2 & i've just got ARMA2 (not installed it yet) i play at 1440x900
GPU is fine. Get more RAM, 2GB not enough. CPU upgrade is probably better than gfx for you. (especially at that resolution, is that native?)
them 720be's look like great clockers, wish i had gone that route could have put the mony i would have saved to another gtx260 :( oh and more ram is always good just make sure your running win 64bit, if you only have 32bit windows you will only see about 3gb but then you could always grab the windows 7 rc for free, i'm running it on all 3 of my pc's and works great
