Lexus IS 2.0 - 174k miles
Permabanned
7 Oct 2008
Lexus IS 2.0 - 174k miles, its up for £2k, my friend wants it as aposed to some 1.0 econobox with 80k miles and windy windows for the same money.
Its from a dealer and the ad claims it comes with an interim service freshly done, full MOT, full TAX, and a 2 year warranty...
With that many miles on it is it a no go and a rather silly option or does the 2 year warrenty negate this?
I wouldnt touch it, but there are others on here who would, its probably coming to the end of its economical service life.
2 year warranty from a dealer with that many miles?!
I would snap their hand off at that price if the warranty was watertight.
How can I tell if the warranty is watertight?
Warranty and Sales Package
All purchases of retail vehicles include the following free benefits:
* National 2 year Warranty
* A MOT
* HPI Clear
* Interim Service
* Full Valet
* Part Exchange Welcome
Finance Available - Prime Finance, great rates available from just £95 deposit. If you have CCJ’s mortgage arrears or defaults we also offer Sub Prime Finance from £0 deposit.
2 Year Warranty
Your free, 4 star, 2 year Warranty is valid Nationwide, any garage can repair your vehicle once the claim has been authorized by VGS Warranties.
The following listed parts are covered by this agreement:
Engine Rocker assembly, inlet and exhaust valves, valve guides and springs (excluding burnt valves and decokes), cylinder head (excluding cracks and overheating damage), stretched head bolts, push rods, camshaft and cam followers, timing gears, chains and tensioner, oil pump, piston and rings, cylinder bores, gudgeon pins, con rods and bearings, crankshaft and bearings, flywheel and ring gear, distributor drive.
Timing Belts Providing there is proof that the manufacturer’s replacement recommendations have been complied with and they are free from oil concentration.
Manual Gearbox Gears, shafts, synchromesh, hubs, selectors, bushes, bearings, speedometer drive, overdrive units (when fitted), solenoid, transfer box.
Automatic Gearbox Gears, oil pump, shafts, bushes, clutches, brake bands, bearings, governors, servos, torque converter, drive plate, valve block, governor, modulator valve, speedometer drive.
Turbo The complete unit (including wastegate, if it is an integral part of the turbo unit and cannot be purchased separately).The agreement applies only if the turbo is fitted as part of the manufacturer’s original specifications.
Drive System – Front/Rear Crown wheel and pinion, half shafts, bearings, planet gears, bevel gears, rear external drive shafts, constant velocity joints, four wheel drive units. Excluding rubber gaiters.
Brakes Master cylinder, wheel cylinders, brake calipers (excluding seizure) servo, brake
pumps, brake limiter valve, ABS computer/pumps.
Steering Rack and pinion, steering box, idler box, power steering rack/ram and pump,
pressure pipes, reservoir, steering column (excluding oil leaks).
Cooling System Water pump, head gasket, thermostat, heater matrix, electric fan motor, viscous fan coupling, radiator, air conditioning pump.
Propshaft Propshaft, universal joints and bearings
Fuel System – Petrol/Diesel Mechanical/electrical fuel pump, air flow meter, EGR valve, idle control valve (excluding injectors).
Front/Rear Suspension Shock absorbers, coil springs, upper and lower wishbones, ball joints, swivel joints, McPherson struts, suspension arms, anti-roll bar, self leveling units, regulator valves and reservoir pump, displacer, hydro pneumatic system excluding bushes).
Wheel Bearings Front and rear wheel bearings.
Clutch Centre plate covered for oil contamination, pressure plate, thrust bearing, clutch fork, master cylinder, slave cylinder.
Electrics Starter/solenoid, alternator, regulator, coil, distributor, ECU (engine only), front and rear window/headlamp wiper motors, heater fan motor, indicator relay, electric window motor, sun roof motor, centralized locking solenoids, horn, cruise control, accuator and control unit only.
Casings In the event of a covered item causing damage to a casing then the casing will form part of the maximum claim liability.
Car Hire In the event of an agreed repair and provided that the repair time according to Autodata schedules is in excess of eight hours a maximum of £20 per day inclusive of VAT (excluding petrol and insurance) maybe reimbursed for up to a maximum of five days.
Vehicle Recovery In the event of an agreed repair Tow-in charges up to £50 including VAT will form part of the maximum repair payout.
Any parts not listed above are excluded from the agreement.
That's what is stated on the website....
As long as its a straight car with a full dealer history and warranty of sorts, I'd take a punt on it. Bullet proof build and what's the alternative? Mondeo? Laguna? 406?
Is it an S or SE, auto or manual and what year is it?
Not sure that someone who's after a 1.0 econo box is going to like paying £400 p/a in tax or 23mpg at the pumps though.....
miles wouldn't bother me, if it turns out to be a lemon your mate can always get a ghia x mondodo for about 1500 quid with less miles.
I looked into these a few years back. Very solid cars, servicing is quite reasonable, the only drawbacks are they're a bit thirsty, the SE wheels are prone to corrosion and the engine's a bit lacking in grunt.
But for that price and with a warranty, do eeeeet!
With the warranty it sounds decent, but most importantly take a look at the condition of the car along with FSH. The IS is a nice car, my mate has one. Is it a navigator version?
