Impact of Water on my i7 ?
My ram is a 1066 but its running at 1600...its the OCZ 6GB kit...which I have to admit wipes the floor with the Corsair XMS3 I bought first time round...cos they struggled when OC'd to 1600MHz...I could OC the OCZ ones higher but the CPU voltage being higher makes the machine unstable...so 4GHz with 1600 on the RAM is fine for me :D
cool i just want mine near 1066 its stupid that my desktop ram is slower than my macbook ram in mhz rating, how much was your watercooling on your desktop i looked at your thread and seems exactally what i want i like the cpu block and its all mounted in the case? though im not sure it would all be able to fit in my case?
Yes the rad which is an XSPC 240 is in the case...I have just fitted a 360 rad to the outside of the case tho...this is for the GPU I am going to water cool...if I was to give a rough guess on how much I have spent just on the CPU for water cooling, I would say about £120 give or take a tenner...
thats really good price, so your running at 4.0 and 1600 ram stable for 120ish on water cooling? seems exactly what i want but with my 1066 ram. Did you spec your parts in your thread as i may just buy the exact same stuff unless you can comment on any changes that i could make. Im not looking to cool m card though, well not just yet as i can still play all my games at stock settings just need to deal with this cpu
I had help picking out the parts, mostly from reflux cos he knows his stuff...but what I will say is: STAY AWAY FROM COMPRESSION FITTINGS IF YOU CAN!!! Cos I have had nightmares getting the correct size and yet I keep being sent the wrong ones...but thats only happened recently...so early days yet lol...but no seriously reflux can give you better explanation on the whole tubing and barb side of things...
and yeah the price I spent is doing really well for what I have bought to cool the CPU :D
i have a friend who has a water cooled cpu so i might talk to him about it tomorrow to figure all the fittings etc, i dont spose you would know but will the system you have fit in a case like the lian li armorsuit i have as many cases i see look bigger, hard to tell the perspective though. This ma be a random question but what would it be like to transport? just as easily as a air cooled pc or is there more to it as ill be moving it in a few months and dont want massive hassle
With regards to moving...best not to put the PC on its side...cos u dont want the coolant moving about to the res, therefore allowing air into the tubing...this means when u turn on the PC you have to do the whole tilting thing again...
with regards to cases like the Lian Li...a set up like mine will certainly fit inside...if you havent already seen it this thread showcases people's water cooling rigs...you might find some interesting stuff in there...I know I did :D
Yep, keep PC upright = job done.
Fittings you just match up to be honest, pretty straight forward.
Nothing wrong with comp. fittings and if your reseller can't get the them right then time for another reseller me thinks ;)
Even if said reseller is OcUK themselves? lol :D I love the guys but I hope this is just a small hiccup :D
My computer is a lot heavier than it used to be, otherwise just as easy to move as before. Probably safer, a waterblock is a lot better than a TRUE for weight hanging off the motherboard.
Compression fittings are awesome. As long as they're machined competantly they remove a point of failure from your system, the joint just isn't going to leak. I'm using 11/8mm compression fittings, which I think is about as awkward as can be. Are you sure the error was on the part of the retailer, and not you ordering mismatched tubing and fittings?
At the op, I think you need to sort out your cable management, and set up the case fans sensibly. If this doesn't knock enough off your maximum temperatures, change to a better air cooler.
Watercooling is a lot of effort, and if you don't research it properly it goes wrong. That you're asking people to 'spec you' instead of excitedly running off and reading all about it suggests it might not be for you. Its fun working out how the components fit together, comparing how they each perform under different situations. Inclination to take short cuts is probably not a sign that water is a good call for you at the moment.
I mean no offense, not everyone things pumping water around a computer is wise. Stick with air until you're sure it can't cope with what you want from it. It's cheaper, and cools almost as well.
As I have said time and time again...the reseller sent me the wrong ones...I didnt order the wrong ones...simple as I will not explain it again...either watch the video I posted a link of or stop assuming I ordered the wrong size.
i just want to save money by getting good parts rather than having loads of errors. a friend with a water cooled pc will help me put it together so knowing loads about it isnt essential i just need to grasp the idea of what parts to look for.
