Can you get out the room?
I've got a piece of paper from underneath the chair, a button thing from the side of the da vinci paintin and a test tube from inside that panel on the left. Stuck now.
The piece of paper tells you how to open the panel of the right of the one you've just opened.
Yes, that is what you're meant to do with it. Have a look at the end of that floorboard. what do you see?
a string? I cant click anythin on it, and the circle on the side of the picture? Dont get what thats for, I hate stuff like this cos I have to finish them.
I've got the chair out of the way but I'm stuck on how to open the thing inside the briefcase, get the key out of the pretty lights panel on the left or how to open the panel on the right.
got 11 items now and im stuck lol
stumbling block is getting the safe open, I have the paper but ive figured thats nout to do with it now, at least the number given doesnt work?
hold the button down for 10 seconds, hwo did you get the chair out the way?
A tip for a tip. You need to open the safe ;) That involves opening the left panel and opening the briefcase.
I've now just got both of the panels to solve and the big box inside the briefcase to figure out.
Edit: There's also a battery hiding inside the plug.
