Hi,
I've recently changed from a Q9550 to a Q9650 (got it fairly cheap) as my Q9550 was a C1 and was quite a hot runner. Anyway, I'm currently using a lapped TRUE Black in push-pull to cool the Q9650 which is giving me reasonable temperatures (50-55c ish under load). So why am I creating this thread? Well, my only concern is that since I've had the TRUE, I have been using the mounting bracket from a Thermalright Ultima 90i, as the bracket that comes with the TRUE is useless at putting any pressure down on the base of the cooler. Now I'm wondering if the bracket from the Ultima 90i is putting enough pressure down on the TRUE as its not really designed for it. This leads me on to whether I should purchase a Megahalems as this seems to be a good cooler with what seems a very good mounting system. What do you guys think?
