Can you get out the room?
done.
i almost snapped my keyboard in two on the last number/letters board
then i noticed the tiny font, the numbers go from 4 to 1 (downwards), not what you expect :p
You need to cut the magnet off the back of the speaker.
I'm drawing the die dots on the coloured bits, but can't get it to open. Should I be doing something else? How do I know which way to draw 6, for example?
draw them like on a die
do the buttons, then click the 'spacebar' so that colour appears
why can't i open the ****ing safe?
do i have to stop exactly on the numbers first time? because that's impossible to guess all 4 numbers when its spinning
For drawing a six you click the two outer columns on the keypad and leave the middle one blank.
ie
oxo
oxo =6
oxo
oxo
xox =5 etc etc
oxo
oxo
xxx
oxo
oxx
xox
xxo
oxx
xxx
xxo
xxx
xox
xxx
Click the safe dial once and it moves one space, no need to hold it in
done, realised i was using the wrong piece of information for the piano bit :/ chess board was easy peasy after that. Thought i was going to end up having to use my screws, but alas. Maybe ill use them to jab the fella in the eyes and nose who locked me in that ruddy room! :)
Yay!!!! Thank god for that, now I can continue with the rest of my life. More rooms? - No thanks not until I am completely bored and have nothing to do!!!
:D
finished! took me bloody ages to find the third hatch, but when i did it was very simple, I put together everything I had, on the second go it worked (first time i didnt re jumble the letters)
I've got loads of items now and in reasonably quick time too. Cant see which wooden floorboard the gold bar should go on. Laptop screen makes it hard to see :o
Where is it?
Edit: NVM, but do you use the knife to cut the string?
i got the code for the safe but how do i do it?
ive never used a safe
If your code is something like 42R34L25R52L
Then you click the safe dial (click the right hand side for right left had side for left) 42R means starting from zero, click the right hand side until you land on 42, then click the left hand side until you land on 34, right until you land on 25, left until you land on 52. Hope that explains it ok..
Where is it?
If you look at the wall the suitcase is at, click the bottom RIGHT corner of the screen by the floor. Should take you into the corner of the room.
top man thanks
