120mm fans for a feser 240 radiator
Permabanned
18 Oct 2002
Stoke on Trent
i know which fans to choose for case fans, but when it comes to choosing a fan for a rad i am stuck, because the CFM means a lot, but it is more important to get a fan with good air pressure, i will be getting some shrouds aswell.
the short list
Scythe Kaze Jyuni 1200RPM Slipstream
Scythe Kaze Jyuni 1900RPM Slip Stream
Scythe S-FLEX 1600RPM Ultra Quiet
Xilence XPF120R Red Wing
Noctua NF-P12 Vortex-Control
Enermax Magma
Feser Triebwerk 120 - Low Speed - TK121LS
the general direction that most people point to is Scythe S-FLEX 1600RPM Ultra Quiet, is this because it has good air pressure? because i dont think that 28dba is silent
Any thoughts at all are most welcome, as i know nothing about radiator fans
I was gonna say S-Flex is good for use on rads. You can always get a fan controller to slow them down a bit and get them a bit quieter if you wanted.
Im using some Enermax Clusters on mine and they seem to be doing pretty good. I think the Magmas are a bit more powerful too so they may also prove pretty good :)
Yes i agree
but i just cant find anywhere that will tell me the air pressure of the fans?
Cheers for that, i dont really know how to read charts like that, and there is no real conclusion
No conclusion is a good thing IMO. As for the charts, just look for a fan which gives good cfm through the radiator vs noise. Some of the quieter fans top out at very low cfm through the radiator eg not good air pressure.
ok i will take a look now
you know what i was doing i was taking the meter on the left as being the DBA not air presure, and all the rads/fans are on pulling air through the rad rather than pushing the air through
