- 4 Oct 2007
Ok, any idea's on how to find the 3rd key? Managed to get the 2 out of the 2 panels but I have no idea where to find the next one.
If you are looking to waste the second half of your day, I've found another one with decent graphics.
Escape From Dr. Kantastic's Guest Room
Can we "fullscreen" these flash games?![]()
That's the gayest game ever. It took about 30 seconds.
Find us a good one then.
White/Crimson/Veridian/Blue. Look them up. They're on fasco-csc.
Help!!
1. c2
2. c1
3. d1
4 b1
with UV
LU=C1
GO= d3
OD=a2
CK=A3
---I've looked at the Good Luck with my UV lamp (and noticed the grid but what combo goes into the Chessboard? I've tried matching them up and my head is fried!
I can only find 3 codes with the UV light.
Hole in the floor, Safe and wall socket
check the lines on the good luck thing..Help!!
1. c2
2. c1
3. d1
4 b1
with UV
LU=C1
GO= d3
OD=a2
CK=A3
GOOD LUCK
on mine these were joined up with lines..
GD
OC
OU
LK
so
GD would be D2
OC would be A3
OU would be A1
LK would be C3
so on the 'chess board'
light up..
D2, A3, A1, C3, and the 4 from above.. (from the paper, that you've typed in)
