hi guys my 328 is given me a couple of problems and i could do with some opinions please. it has done 150,000 miles, fsh, well looked after car.
problems:
1: engine has a little wobble on idle i think its a misfire and you can hear it in the exhaust at the back
2: it has now stopping revving above 5400 rpm instead it gets there then theres like a rev limiter but it bounces up and down crazy.
it has had new plugs, and i've swapped the coil packs from a low milage car, the engine has also been compression tested and its fine.
i have tried it without the maf sensor, just the same (prevous owner also also said its had a new maf)
it is going on a diagnostic machine on thursday/friday to see if out shows up
my mate is a mechanic and knows a fair bit about bmw's, he is convinced its the catalytic converter as there isnt much pressure coming out of the pipes at the rear of the car, and it also stinks (had 9 cars never had a smelly exhaust lol)
does anyone here have any ideas??
thanks, dan.
problems:
thanks, dan.
