Can you get out the room?
Well, I cannot get the 2nd panel lock to work, I have read everything I can find and still my combination of colours and numbers from the dice do not work. How annoying.
I've scanned all those places but none have GD
they all have
OD LU CK GO
thats enough, you only need four (as you have) those four become the last four on the sheet of paper (with 4 scrubbed out) then enter those into the chess board in order and the key to let you out appears
enter the first number on the panel before hitting the enter key, i had the same thing
so for me the first colour was yellow (which was a 6), so I'd enter six before hitting the enter key
Right panel hold button for 10 seconds. Socket on the wall use the pen knife to pull the casing off then use the screwdriver on the pen knife to unscrew the plug thing. Board in the corner put the gold brick on it and slice the wire with the knife.
did that, stuck still LOL
pen light is activated now, comes up with a code where ever you put it its the same code, dunno where to go now at all :(
OMG I get home and this is on 13 pages?! :eek:
I don't know if I even have the time to use the walkthrough! :p
BB x
I gave up after about 5 minutes, Not because i was stuck but because I couldnt be bothered to figure out the colour codes in the game. Maybe when i'm in a more "productive" mood! Maybe i'll do it in work. :p
Yeah thats what I have been trying, doesn't seem to work.
I have a dice that is light blue (2), red (4), yellow (6).
colour order is pink, dk blue, light blue, red, green, yellow.
So.I have been going:
1.Enter
2. Enter
3. highlight the shape of a 2, enter
4. highlight the shape of a 4, enter
5. Enter
6. Highlight the shape of a 6, enter
I used the dice shapes from a post further back. Still no noy.
1.Enter
2. Enter
5. Enter
click the dice with the UV on it and you will get the other three colour designations
