Spec me a pocket knife
  • Thread starter Thread starter ajf
  • Start date Start date
ajf
ajf
30 Oct 2006
Worcestershire, UK
I need a new pocket/pen knife.
Anyone got suggestions for good quality one? Don't want a multi knife, just something with a good blade for opening parcels, stripping cables, cutting cable ties etc etc.
Andrew
Deffo a Wenger or Victorinox Swiss Army Knife.
Here's mine:
Had it for about 4 years now. Comes in very useful. I love pulling it out in front of my mates. :D
lmao, i didnt mean threatening them!!
I meant like when someone fiddling around to cut/open something, I pull it out and cut it for them!
The funny thing is , that's not a fake :D
Code:
    * 10 mm detachable hexagonal wrench - Screwdriver - Spoke key (3.3 mm and 3.5 mm) openings - Extension lever 10 mm detachable hexagonal wrench - Screwdriver - Spoke key (3.3 mm and 3.5 mm) openings - Extension lever
    * All-purpose wrench (exclusivity) All-purpose wrench (exclusivity)
    * Bit holder Bit holder
    * Blade with blunt point Blade with blunt point
    * Can opener Can opener
    * Case opener Case opener
    * Chain rivet setter Chain rivet setter
    * Cigar cutter (patented) Cigar cutter (patented)
    * Club face cleaner (exclusivity) Club face cleaner (exclusivity)
    * Combination tool : Screwdriver with safety lock system (exclusivity) - Can opener - Cap lifter Combination tool : Screwdriver with safety lock system (exclusivity) - Can opener - Cap lifter
    * Corkscrew Corkscrew
    * Curved hexagonal key Curved hexagonal key
    * Detachable marker Detachable marker
    * Fish scaler - Fish disgorger - Lineguide Fish scaler - Fish disgorger - Lineguide
    * Flat Phillips screwdriver Flat Phillips screwdriver
    * Flat pliers Flat pliers
    * Flat screwdriver 3.5 mm with safety lock system (exclusivity) Flat screwdriver 3.5 mm with safety lock system (exclusivity)
    * Flat screwdriver with safety lock system - Cap lifter - Wire bender Flat screwdriver with safety lock system - Cap lifter - Wire bender
    * Graduated tread depth gauge (mm/inch) uses detachable sliding bit holder Graduated tread depth gauge (mm/inch) uses detachable sliding bit holder
    * Green repair tool Green repair tool
    * Green repairer Green repairer
    * Integrated holder Integrated holder
    * Integrated swivelling compass with sight line (exclusivity) - Ruler cm + inch (exclusivity) Integrated swivelling compass with sight line (exclusivity) - Ruler cm + inch (exclusivity)
    * Junior round blade Junior round blade
    * Large blade Large blade
    * Laser pointer Laser pointer
    * Magnifying glass - Precision screwdriver Magnifying glass - Precision screwdriver
    * Medium screwdriver - Cap lifter - Wire bender Medium screwdriver - Cap lifter - Wire bender
    * Metal file - Metal cutting saw Metal file - Metal cutting saw
    * Nail clipper (exclusivity) Nail clipper (exclusivity)
    * Nail file - Nail cleaner - Screwdriver for small cross head screws Nail file - Nail cleaner - Screwdriver for small cross head screws
    * Needle nose pliers / Wire-cutter / Nut wrench Needle nose pliers / Wire-cutter / Nut wrench
    * Phillips screwdriver Phillips screwdriver
    * Phillips screwdriver with safety lock system (exclusivity) Phillips screwdriver with safety lock system (exclusivity)
    * Reamer Reamer
    * Reamer - Eye Reamer - Eye
    * Reamer - Needle - Cuticle pen Reamer - Needle - Cuticle pen
    * Ring Ring
    * Safety lock system (patented) Safety lock system (patented)
    * Semi-round-nose pliers - Wire-cutter - Nut wrench Semi-round-nose pliers - Wire-cutter - Nut wrench
    * Serrated-edge scissors and lever (patented exclusivity) Serrated-edge scissors and lever (patented exclusivity)
    * Shackle opener - Marlin spike - Ruler inch/cm - Needle Shackle opener - Marlin spike - Ruler inch/cm - Needle
    * Shoe spike wrench Shoe spike wrench
    * Slip-joint pliers (exclusivity) - Wire crimper - Inside and outside wire cutters - Nut wrench Slip-joint pliers (exclusivity) - Wire crimper - Inside and outside wire cutters - Nut wrench
    * Small blade Small blade
    * Small blade 65 mm Small blade 65 mm
    * Small screwdriver Small screwdriver
    * Snap hook Snap hook
    * Special blade Special blade
    * Spot light Spot light
    * Stroke counter with 12 graduations Stroke counter with 12 graduations
    * Toothpick Toothpick
    * Tweezers Tweezers
    * Wood saw Wood saw
Leatherman Juice CS4 is what i have, i know its a multi tool but you wont find a better quality product for the price. And the blade is "nearly cut your thumb off" sharp :)
just have a small leatherman knife old model (there is plenty with minimal features), 2.8 inch blade perfect for opening letters and has some kind of weird aura of making you feel safe when camping alone in the wild :D. didn't want a multi tool as have a seperate thing with a screwdriver ect.
Thanks all for the suggestions. I will check them out and see which suits the purpose best. I can go for a multi tool, just don't want one with 101 different gubbins on it.
That huge one is also on a well known 'forest' website....
Andrew
