Can you get out the room?
Hmm I assume this light isn't the same as the UV people are talking about? All I see no matter where I use it is the safe code..
edit: nm figured it out. Evil game :/.
finally done it ...found it a bit annoying tbh
sit a bit away from my monitor so was a bit hard to spot stuff...full screen option and it would have been a fair bit easier(and more enjoyable for me).
Never been so happy to see a door handle in all my life.
Surprisingly i found the first color coded safe the most dificult.
just blew myself up in the swans room... at least i got out though? :D
no idea how to work out what wires to cut.
Finally im out. had to use a walkthrough in the end to get the codes part. no way im staying up to figure out that bit, spent over an hour just getting everything open. i can safely say i hate that game with a passion and only when im really angry at someone will i link them to it. but once you've started you have to finish.
I have the gold bar, but the bugger won't drop anywhere on the floor (I tried clicking every square inch of it :p)
What am I doing wrong?
Cheers,
Su
ROFL thats one of the easiest things to do all you have to do is move the first slider untill you hear a high pitched beep then the second etc should take no more than 30 seconds to do.
My ears must be broke, I did that starting on the right hand slider but didn't hear a change. :(
Cheers,
Su
Corner of the room, right side of the briefcase. One of the planks is slightly off colour if I remember. If it's not, then click around in that area without the bar. SOmething should rise up. Then put the bar on it.
toughest part i found was finding the batteries for the uv lamp.....if i didnt read it on these forums i'd probably still be stuck from last nite:o
I'm giving up.
Just opened the safe but I can't do the tone generator bit as I have no sound, hence I can't proceed :(
