Any thoughts on the Antec CP 850W PSU?
31 Jan 2009
Newcastle Upon Tyne
I am thinking of purchasing this cos of its modular features and the fact that all the other cables are put to one side which will give for better cable management.
Can anyone tell me if they have one already and how they have found it?
Thanks :D
dont have one, theyre meant to be really good, but just to make sure you are aware, theyre not ATX factor, theyre their own cp factor, bigger than atx, and as such only fit in the antec1200 and P193 cases, dont fit any others afaik so if youve got one of them then youre ok, if not youll have to go for a normal atx psu
lol dont worry I have an Antec 1200 case which is why I asked...I know which cases they are meant for...thanks :D
What case you got? It only fits certain Antec cases, the 1200 P183, and P193.
I have a P183 and the CP 850w it is a very very good PSU. I'm very very happy with it :)
:D
was just making sure, Im sure someones got to of bought one without realising
theres a good review here, as I say theyre meant to be really good
Ah thats a good review :D thanks...I will think about buying it in the next month or two...seems like a damn good PSU...
Yes I mentioned I do have an Antec 1200 :D
