- 10 Sep 2008
- Bangor, Northern Ireland
Im stuck in the "other room" cant figure out what the hell to do!!
I have a funny box thing with a latch, and all the above, and found several codes around.
My brain is failing, I don't even know what to do with the different puzzles :/
What do you have, ive just finished...
A wine glass
What looks like a manual drill
Corkscrew
Some weird metal things with prongs I can press
A screwdriver handle
A note that says "New sence"
A doll that I have put in the correct pose
Ans a funny box with a latch you can look into.
Finished the vision one
The ending is very well done.
Very hard - I've got what looks like a hand wrench, a socket, something with a few adjustable prongs on, a doll and used the wine to make some sort of emerald and now I am struggling
I don't think so? I've seen the box with what looks like a frog on top of it in the wall unit is that the one you mean? I see it's screwed in and the handle of the clock appears to be a screwdriver but I can't work out how to get it off......if you could give me a pointer in the right direction without blatantly giving it away?
bit tough i thought!
Gah, I'm stuck after putting the second piece into the circular wall... thing!![]()
Click on 'room escape games' on the top menu and there are another 6, all rated easier than that one though.
