Can you get out the room?
I have a funny box thing with a latch, and all the above, and found several codes around.
My brain is failing, I don't even know what to do with the different puzzles :/
What do you have, ive just finished...
look at the map on the table...
have you seen the symbol on the map before?
NEWSENSE
North
East
South
West....
A wine glass
What looks like a manual drill
Corkscrew
Some weird metal things with prongs I can press
A screwdriver handle
A note that says "New sence"
A doll that I have put in the correct pose
Ans a funny box with a latch you can look into.
Look above... you have a circular object with four buttons...
and you also have a map on the table with the same symbole pointing to north?
you also have a piece of paper saying
NEWSENSE....
(p.s- this is worse than the other game, its stupidly difficult...)
Very hard - I've got what looks like a hand wrench, a socket, something with a few adjustable prongs on, a doll and used the wine to make some sort of emerald and now I am struggling
you have the wierd box? with the latch?
I don't think so? I've seen the box with what looks like a frog on top of it in the wall unit is that the one you mean? I see it's screwed in and the handle of the clock appears to be a screwdriver but I can't work out how to get it off......if you could give me a pointer in the right direction without blatantly giving it away?
what do you have how far are you?...
have you lifted the plantpot off the desk yet....
wow that last one was very long and hard, took me a grand total of about 1hr 30 mins lol
