This Week Only 08/07/2009
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
36 new amazing weekly deals here available on our This Week Only page, offering you selected products all substantially reduced in price for a one week period - some of the highlights for this week are :-
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - OEM + World In Conflict PC Game
Ultra Overclockable D0 Stepping (SLBEJ) Version to allow the highest overclocks and lowest temperatures possible. Achieve 975 performance at 920 pricing.
Nehalem is a radically new design for Intel: for the first time, the CPU is a 'native' quad-core CPU, where all four cores sit on the same piece of silicon. With its Core 2 CPUs, Intel used two dual-Core dies to create a quad-core chip, this translates into better performance. Nehalem features Level 3 cache, something first seen on earlier Xeon server chips, but Intel Core i7s will feature up to a massive 8MB (shared between all four cores). Each of Nehalem's four cores has 256KB of lower-latency Level 2 cache.
The Level 3 cache of Nehalem is described as being ‘inclusive’, meaning that it holds the data of all the Level 2 caches. This means that if a core needs to fetch data, and it doesn’t find it in the Level 3 cache, it can be confident that the most up-to-date version of that data is held in system memory and fetch straight from there. If the Level 3 cache wasn’t inclusive, the core would first have to look at the cache of the other three cores to ensure that none of them had a more recent version of the data it needs. An inclusive cache is therefore said by Intel to be more efficient than an ‘exclusive’ cache design, even if it does mean that 1MB of Nehalem’s 8MB Level 3 cache is taken up by storing a copy of the 256KB Level 2 cache inside each processing core, again this translates into a performance gain over Intels previous designs.
Intel has integrated the memory controller onto the Nehalem CPU die rather than having it be part of the Northbridge on the motherboard. It's achieved this by modularising the design of the CPU. The seperate processing cores and caches are linked to the onboard memory controller via a new bus standard called QuickPath (sometimes called QPI, short for QuickPath Interconnect). As QuickPath replaces the Frontside Bus (FSB) and Northbridge combo, it also takes over the role of allowing the CPU to connect to other system components, busses and controllers such as the PCI Express controller and DDR3 memory.
The last big news about Nehalem is that it uses Hyper-Threading. This technology works just as it did with the Pentium 4, using spare resources of a processing core to try to execute a second process thread. This means that a quad-core Nehalem processor can accept and attempt to process eight threads simultaneously, making it even more massively parallel than the current Core 2 Quad CPUs.
- Lithography Process: 45 nm
- Cores: 4
- Threads: 8
- Frequency: 2.66 GHz
- Cache: 256 KB L2/core and 8 MB shared L3
- Memory Controller: Triple channel DDR3 800/1066/1333 MHz
- Bus Interface: 1x 4.8 GT/s QuickPath
- TDP: 130W
- Socket: LGA1366
- D0 Stepping (SLBEJ) for extreme Overclocking
- This is an OEM Product and is not supplied with heatsink and fan
- Includes World In Conflict Complete Edition Game
BUY NOW at only £199.99 inc VAT
Draytek Vigor 2710N 300Mbps Wireless-N ADSL2+ Router with Storage Port
The Vigor2710 is a highly integrated ADSL2/2+ router with VPN capability targeting SOHO(Small Office and Home Office) and residential broadband access requirement. These integrated network access devices not only offer rich functionality with up to 24Mbps bandwidth in downstream but also bandwidth management for multimedia applications. The integrated economical design makes the ideal balance of ease of use and secure network management.
Besides powerful firewall protection against malicious Denial of Service(DoS) attacks, the Vigor2710 is designed with more advanced security feature such as Stateful Packet Inspection(SPI) to offer network reliability by detecting attacks and prohibits malicious penetrating packets from entering internal network.
The easy-to-use CSM (Content Security Management) can prevent family from the connection to Web sites that contain illegal or objectionable content. The use of bandwidth/session consuming Peer-to-Peer (P2P) applications can be properly managed by embedded CSM.
You can attach USB storage device to USB port of Vigor2710 to share files. Or, you can use USB printer by connecting it to USB port.
Furthermore, embedded with VPN support for confidential remote access, the Vigor2710 is equipped with powerful DES, 3DES encryption engine and automated key management via IKE to easily create 2 simultaneous VPN tunnels.
BUY NOW at only £109.99 inc VAT
Logitech MX518 Gaming-Grade Optical Mouse (910-000616)
If you´re going to play at the highest level, you need a mouse that gives you an edge. The Logitech MX518 Gaming-Grade Optical Mouse does exactly that with its ultra-high resolution, 1600-dpi MX Optical Engine that delivers lightning-fast response and mirror-smooth tracking. The MX518´s advantages don´t stop there. You get instant, on-the-fly sensitivity adjustment that lets you switch effortlessly from pixel-precise targeting to fast-twitch acceleration, without any software. And the contoured grip ensures peak performance and comfort, even during the most intense gaming sessions.
- Award-winning Logitech® MX™ Optical Engine
- “On-the-fly” sensitivity adjustment to 1,600, 800, and 400-dpi resolution
- 5.8 megapixel/second image processing
- Up to 15 g of acceleration
- Expanded 16-bit data format supports blazing fast moves with pure precision
- Advanced gaming software, exclusive to Gaming-Grade™ mice, for up to five custom sensitivity settings
- Super-slick gaming feet for effortless, precise tracking
- Contoured grip ensures peak performance and comfort—even in the most intense gaming sessions
- Three-year warranty
BUY NOW at only £20.99 inc VAT
Coolermaster HAF 922 Case - Black (No PSU)
Following the success of the full tower HAF 932, Cooler Master extends the line to a mid tower with the HAF 922. It has a rugged strong appearance and outstanding protection designs that characterize a beast yet to be tamed. Without a doubt this mid tower has it all! It accommodates all sorts of high-end hardware from its spacious interior, and supports up to three 200 mm fans for maximum airflow at minimum noise. This mid tower chassis represents a disorderly collision of machine and beast.
- Extreme airflow, uncompromising cooling performance, ruggedly strong with outstanding protection
- Accommodates demanding high-end components including full length graphics cards
- LED ON/OFF switch for front 200 x 30 mm fan
- Patented button design for easy maintenance of 5.25" drive devices
- PSU bottom fan can be setup facing up or down to increase airflow through out the case
- Tool free installation
- Includes cable management and CPU retaining hole for easy customizability
- Spacious interior accommodates with the radiator
- 7+1 PCI expansion slots for increased expandability
- I/O Ports: USB 2.0 x 2, MIC x 1, Audio x 1 (support HD / AC97 Audio), eSATA x 1
- 5 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- Front Cooling: 1x RED 200mm fan (700RPM)
- Rear Cooling: 1x 120mm fan (1200RPM)
- Top Cooling: 1x 200mm fan (700RPM)
- Side Cooling: 1x 200mm fan optional
- Bottom Cooling: 1x 120mm fan optional
BUY NOW at only £88.99 inc VAT
OCZ ModXStream Pro 700w Silent SLI Ready ATX2 Modular Power Supply
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 140mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 86% efficiency at typical load and up to 82% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power. Available in configurations ranging from 400W to 700W and backed with OCZ’s 3-year “power swap” warranty, the OCZ ModXStream Pro gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- 150 x 160 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- up to 86% Efficiency
- Overvoltage/OverPower/Short-Circuit protection
- (.99)Active PFC
- MTBF: 100,000 hours @ 25C
- 1 x 20/24-pin ATX
- 1 x 8-pin CPU
- 1 x 4-pin CPU
- 1 x 6-pin PCI-E
- 1 x 6+2-pin PCI-E
- 4 x Peripheral
- 2 x Floppy
- 6 x SATA
BUY NOW at only £67.99 inc VAT
Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache - OEM (ST31000528AS)
- (.99)Active PFC
- 1 x 20/24-pin ATX
- 1 x 8-pin CPU
- 1 x 4-pin CPU
- 1 x 6-pin PCI-E
- 1 x 6+2-pin PCI-E
- 4 x Peripheral
- 2 x Floppy
- 6 x SATA
BUY NOW at only £62.99 inc VAT
XFX ATI Radeon HD 4870 1024MB GDDR5 PCI-Express Graphics Card
The ATI Radeon HD 4800 Series GPUs bring the power of graphics ‘supercomputing’ to gamers, setting a new standard for visual computing. Redefine the way you play and take HD gaming to the extreme with best-in-class performance. The new TeraScale graphics engine delivers an immersive, cinematic gaming experience. Add this GPU to your PC and watch Blu-ray movies and play HD content with incredible visual fidelity. Do it all with break-through efficiency that doesn’t compromise performance. With enhanced memory architecture that is able to handle 115GB a second, the ATI Radeon HD 4870 is the only graphics card available with blazing fast GDDR5 memory. Featuring nearly one billion transistors and up to 800 stream processors, the high resolutions and fast frame rates that were once the sole domain of dual-card systems are now yours.
- ATI Radeon HD 4870 GPU @ 750MHz
- 1024MB GDDR5 Memory @ 3600MHz
- 24x custom filter anti-aliasing (CFAA) and high performance anisotropic filtering
- PCI Express 2.0 support
- ATI CrossFireX Multi-GPU Technology
- Microsoft DirectX 10.1 support
- Shader Model 4.1
- ATI Avivo HD video and display technology
- Unified Video Decoder 2 (UVD) for Blu-ray and HD Video
- Built-in HDMI with 5.1 surround sound support
- On-chip HDCP
- 2 Year Warranty
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA/ testing terms and conditions (http://www.overclockers.co.uk/support.php)
BUY NOW at only £114.99 inc VAT
