***Official Gigabyte X58 Overclocking Thread.***
19 Jan 2008
Sunny Wales.
As the Gigabyte X58 boards seem to be very very popular and with so many owners on here thanks to Ocuk and there bundles it seems a official thread for all the owners to share knowledge and tips.
Iv not touched mine yet but maybe people can share there screenies of stable clocks to help guys that are trying to get the hang of i7 and the boards many settings.
Here is a bios profile.
K need alittle advice here. Im trying to get stable at 4.2Ghz but LinX BSOD after 4 mins which makes me think its not a Vcore problem It will do 4Ghz @ 1.16v load but at the moment trying to get 4.2Ghz @ 1.23v load.
Heres my settings. Im totally lost when it comes down to all the other voltages. This is where i could do with the advice.
4.2Ghz 920 D0 BSOD after 4 mins of LinX.
CPU Clock Ratio [20x]
Advanced CPU Features [Press Enter]:
Intel(R) Turbo Boost Tech [Enabled]
CPU Cores Enabled [All]
CPU Multi Threading [Enabled]
CPU Enhanced Halt (C1E) [Enabled]
C3/C6/C7 State Support [Disabled]
CPU Thermal Monitor [Enabled]
CPU EIST Function [Enabled]
Virtualization Technology [Disabled]
Bi-Directional PROCHOT [Disabled]
Uncore & QPI Features [Press Enter]:
QPI Link Speed [x36]
Uncore Frequency [x16]
Isonchronous Frequency [Enabled]
Advanced Clock Control [Press Enter]:
standard clock control
Base Clock (BCLK) Control [Enabled]
BCLK Frequency (MHz) [200]
PCI Express Frequency (MHz) [AUTO]
C.I.A.2 [Disabled]
advanced clock control
CPU Clock Drive [ 700mV]
PCI Express Clock Drive [ 700mV]
CPU Clock Skew [ 0ps]
IOH Clock Skew [ 0ps]
Performance Enhance [Turbo]
Extreme Memory Profile (X.M.P.) [Disabled]
System Memory Multiplier (SPD) [x8]
DRAM Timing Selectable (sPD) [Manual]
Channel A
CAS Latency Time 8 [9]
tRCD 8 [9]
tRP 8 [9]
tRAS 20 [24]
Channel B
tRCD 8 [9]
tRP 8 [9]
tRAS 20 [24]
Channel C
tRCD 8 [9]
tRP 8 [9]
tRAS 20 [24]
Advanced DRAM Features [Press Enter]:
Extreme Memory Profile (X.M.P) [Disabled]
System Memory Multiplier (SPD) [AUTO]
Advanced Voltage Control [Press Enter]:
Load Line Calibration [Enabled] (Whats peoples views on this?)
CPU Vcore 1.15v [1.28125v]
QPI/VTT Voltage 1.150v [1.280v] (Tried from 1.28v-1.36v with no change in how long it takes to BSOD)
CPU PLL 1.800v [AUTO]
MCH
PCIE 1.500v [AUTO]
QPI PLL 1.100v [AUTO]
IOH Core 1.100v [AUTO]
ICH I/O 1.500v [AUTO]
ICH Core 1.1v [AUTO]
DRAM
DRAM Voltage 1.500v [1.66v]
DRAM Termination 0.750v [AUTO]
Ch-A Data VRef. 0.750v [AUTO]
Ch-B Data VRef. 0.750v [AUTO]
Ch-C Data VRef. 0.750v [AUTO]
Ch-A Address VRef. 0.750v [AUTO]
Ch-B Address VRef. 0.750v [AUTO]
Ch-C Address VRef. 0.750v [AUTO]
4095MHz 920 D0 30 LinX passes - fully stable.
CPU Enhanced Halt (C1E) [Disabled]
CPU Thermal Monitor [Disabled]
CPU EIST Function [Disabled]
Virtualization Technology [Enabled]
Bi-Directional PROCHOT [Enabled]
BCLK Frequency (MHz) [195]
C.I.A.2 [Disabled]
DRAM Timing Selectable (sPD) [Auto]
Channel A
tRCD 8 [9]
tRP 8 [9]
tRAS 20 [24]
Channel B
tRCD 8 [9]
tRP 8 [9]
tRAS 20 [24]
Channel C
tRCD 8 [9]
tRP 8 [9]
tRAS 20 [24]
Load Line Calibration [Enabled] (I dont see a point in VDroop at all :S)
CPU Vcore 1.15v [1.275]
QPI/VTT Voltage 1.150v [1.335)
CPU PLL 1.800v [1.8]
MCH
PCIE 1.500v [AUTO]
DRAM
DRAM Voltage 1.500v [1.64v]
I'd bump the IOH core upto 1.140v, Mine simply isn't stable at 4ghz below that, pretty much an instant BSOD as soon I start a CPU intensive task below 1.140V.
Also you may need to bump the QTI/VTT voltage in line with your Vcore and memory voltage. Some I7's like mine won't work happily with your memory running at a high 1.65ish V with out upping the QPI/VTT voltage a simlar ammount. I have my VTT @ 1.34v and memory at 1.64v , my QTT becomes unstable or it just doesn't comunicate with my memory properly at 1.32v and lower without dropping the memory voltage and speed too.
Also you CPU just might not be stable at that speed period without a higher Vcore. My vcore is set to 1.2875v in the bios, CPU-Z reports 1.248V under full load.
Hmmmm well i kinda gave up on 4.2Ghz for the mean time as anything much over 1.23v and my temps go crazy. I feel its close to been stable but needs a lot more tweaking.
