Don
- 20 Oct 2002
- In a house
How does one know if you should be using it or not? My mate runs it in a VXR Astra and says he has to and its better for it but i'd have thought it was for a lot higher spec machines. He also has some funny notion about sitting in the car for 5 minutes at a standstill before he switches it off and turns off the key. Some 'essential cooldown period' apparently.
Turbo car then, standard procedure on most hot turbo cars. Some users just back it off for the last few miles to avoid boost to allow it to cool.
When you turn the engine off, the turbo loses its coolant supply, and can damage the thing if it gets too hot.
You can get "turbo timers" that allow the engine to run on for a few minutes, after getting out and locking the car. Saves you sitting about waiting
