[timko];14450336 said:It's the fsb that is quad pumped (450 x 4 = 1800) not the RAM. An fsb of 450Mhz with a default 1:1 divider results in an actual ram speed of 450Mhz (900mhz effective due to double data rate).
Your OCZ ram is rated to run at 1600Mhz effective double data rate @ CL7, which means its actual ram speed is 800Mhz. The 1800mhz CL9 you refer to is an actual speed of 900mhz.
The Q6600 you have now has an fsb of 266mhz. If you haven't overclocked your current Q6600 and you are using a 1:1 divider with your OCZ ram then you would currently be running the ram at an actual speed of 266mhz. As such, using the same divider and pushing the fsb to 450mhz also results in 450mhz actual ram speed, still well below 800Mhz CL7 and 900mhz CL9.
Even if you was to use the next available higher divider of 4:5 your ram would still only be running at an actual speed of 563mhz. Here's a list of dividers used with 450mhz fsb; and the resulting actual ram speed and effective in brackets:
FSB of 450Mhz and different dividers
1:1 = 450mhz (900mhz)
4:5 = 563mhz (1126mhz)
2:3 = 675mhz (1350mhz)
3:5 = 750mhz (1500mhz)
1:2 = 900mhz (1800mhz)
As you can see, you're not going to hit 900mhz unless you use the high 1:2 divider with 450mhz fsb.
Most bioses won't use 1:1, 4:5 labels for dividers and will instead use multipliers (2x, 2.4x etc) or they will just show the resulting actual or effective ram speed as you cycle through the options.
If you want to quickly see what divider you are currently on then just download CPU-z, run it and goto the "Memory" tab.
Hope this helps clear things up a bit![]()
I will not reach the rated 800MHz (1600MHz)1:1 = 450mhz (900mhz)
and I don't fancy the latency involved with the 900MHz(1800MHz)
What's your current q6600 clocked at,?
So at the minute I have my ram sitting at 800MHz (1600MHz) @CL7
CPU FSB - 400MHz
CPU multiplier - x8
Ram divider - 1:2
Hey all,
So im selling my Q6600 and a few other components not being used and I was wondering whble at 3.6ghzich of these two processors is the better choice for me.
Why are you selling a Q6600 for a Intel Core 2 Quad Q9650 ?
You do know that the yorkfields offer around 200mhz clock for clock over the kentsfields?
Your upgrade is pointless and a waste of money.
I have clocked many Q6600's and not one of them has failed to be prime stable at 3.6ghz.
I ran mine at 3.8ghz 24/7
If you must upgrade then core i7.
As getting a Intel Core 2 Quad Q9650 is a pointless upgrade over a Q6600 on every level.
I'd go for a Quad, agree with BIGBC as well, I have a Q6600 and friend has a Q9550, noticable difference.
I don't think I said this.I was wondering whble at 3.6ghzich of these two processors is the better choice for me.
But even then I'm even less than 3.2GHz if I try that.CPU FSB: 450Mhz
CPU Multiplier: 7x
Ram divider: 1:1
Especially in winter where your CPU stops heating your room![]()
[timko];14460313 said:I hope some of my long posts were useful![]()
I'd give you some plus rep if that is possible?![]()
Thats a new one [timko], I can see the headlines now . .[timko];14460362 said:Something similar is found by clicking on the "Trust" button on the bottom of my posts![]()
I upgraded my Q6600 to a Q9550 and have seen performance increases in several different applications, especially when multitasking.
Quad is a winner in my book =]
In what?I'd go for a Quad, agree with BIGBC as well, I have a Q6600 and friend has a Q9550, noticable difference.
The reason I was planning this upgrade was that I cannot get my system IBT stable a notch over 3.2GHz and the voltage required to get it stable brings my processor to 80 degrees!!!
My goal would have been 4GHz with the Q9650
@easyrider
The only other option I can see is to replace my OCZ Vendetta 2 with something else. Grab some AS5 and do as [timko] said, and try for my max stable fsb with the Q6600.
Am I mistaken that games would respond to a higher clock frequency rather than the 450MHz?
