Either, the use of in the English language.
19 Dec 2006
UK
Right, had some guy attempt to correct my english at work last night and I'm not convinced he is right at all so I call upon the knowledgeable patrons of OcUK.
Customer: "I'd like a box of matches or a cigarette lighter"
Me: "I have both so you can have either"
Customer: "You mean or, I can have matches or a lighter."
Me: "Erm no, I have both matches and lighters available and as such you can have either of them."
Ignoring the proviso that the customer is always right was I incorrect to use either is such a context?
Oh, and then Athlete came in and bought some Monster Munch :)
I can't think of any context where saying "I have both so you can have or" makes any sense, so I guess you were right. Why the customer saw the need to "correct" you regardless of whether you were in error or not makes no sense to me. You should have drop kicked him over the counter for insulting you.
You were correct, but why argue with someone who wants a lighter or match? :)
Because of his attitude to be honest, he clearly thought I was some sort of idiot just because I was working the night shift in a fuel station.
I'd say you were correct but either would be fine.
Wiki said:
Either/or means "one or the other." It usage versus the simple or structure is often for emphatic purposes, sometimes intending to emphasize that only one option is possible, or to emphasize if there are only two options. Its use in a sentence lets the reader/listener know in advance that a list of two or more possibilities will be given. Its negative is neither/nor, meaning "none of them".
Both were right.
"I have both, so you can have either"
"I have both, so you can have the matches or a lighter"
He was just being a glute and trying to seem superior. I'd have got the lighter out and set his comb-over on fire.
