- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
I have brought Thermaltake casing back to Overclockers. Thermaltake have upped their game and designed some new truely great looking case with some awesome features. I have not listed some of the older cases which were not great, but these new lines are very exciting.
Thermaltake Element S Case - Black (No PSU)
Silent, cool and stylish are the hallmarks of a classic case. The Element S hits the mark on every level; featuring large quiet fans to maintain maximum airflow, anti-vibration and noise material is applied to the side panels, stealth black interior shows off the quality both inside and outside and when combined with excellent build quality makes the Element S the best Thermaltake case ever.
- Anti-vibration & noise reduction materal on side panel
- Stealth Black Interior
- Massive Storage Capability with 7 x 3.5" and 2 x 2.5" HDD bays
- Direction-free HDD cage
- Excellent thermal performance with optimal air flow
- Folding edge design to strengthen structure and prevent cutting
- Front (intake): 120 x 120 x 25 mm TurboFan, 1300 rpm, 17 dBA : 120 x 120 x 25 mm (optional)
- Rear (exhaust): 140 x 140 x 25 mm TurboFan, 1000 rpm, 16 dBA
- Top(exhaust): 230 x 230 x 20 mm red LED fan, 800 rpm, 15 dBA
- VGA (exhaust): Two 60 x 60 mm fan (optional)
- Drive bays: 3 x 5.25" and 7 x 3.5"
Only £94.99 inc VAT.
BUY NOW
Thermaltake V9 Case (VJ40001N2Z) - Black (No PSU)
With a feature list that reads like a gamers dream the V9 is one of the best gaming cases on the market today. The 23cm top fan moves enough air to cool even the hottest of hardware, be it multiple graphics cards or an array of hard drives. Ideal for cable tidying thanks to strategically placed holes behind the motherboard tray the V9 is a joy to build in.
- Top 23cm silent fan Built-in
- Metal grilled front panel
- Bottom-placed PSU design for better and easier installation.
- MB tray fan hole pre-drilled for better MB ventilation.
- Tool-free installation for 5.25", 3.5" and PCI devices.
- Front (intake) :120 x 120 x 25 mm fan or 140 x 140 x 25 mm fan
- Rear (exhaust) :120 x 120 x 25 mm TurboFan (1300rpm, 17dBA)
- Side (intake) : Optional 120 x 120 x 25 mm fan x 2 or 140 x 140 x 25 mm fan x 2
- Top (exhaust) :230 x 230 x 20 mm
- MB Tray (intake) : Optional 70 x 70 x 10 mm fan
- Drive Bays: 4 x 5.25" and 7 x 3.5"
- I/O Ports: 2 x USB2.0 and 1 x HD Audio
Only £56.99 inc VAT.
BUY NOW
Thermaltake VI1000BNS M9 Tower Case - Black (No PSU)
The M9 VI1000BNS by Thermaltake is a well-designed PC case that includes nine 5.25" bays, so you can build the configuration of your choice. The M9's two 12-cm front and rear fans provide optimum cooling. Plus, this case's front panel has a metal grill meant to increase airflow and light up your computer's parts. The M9 VI1000BWS PC case from Thermaltake has been designed to ensure a long life for your computer by effectively protecting it from overheating.
- Case Type Mid Tower
- Front Bezel Material
- Color Black
- Motherboard Support Micro ATX and Standard ATX
- Motherboard Tray
- 5.25" Drive Bay 9
- Ext. 3.5" Drive Bay 1 (convertable from 5.25")
- Int. 3.5" Drive Bay 3
- Expansion Slots 7
- Front I/O Ports USB x 2 & HD Audio
- Front (intake) Cooling: 120 x 120 x 25 mm blue LED fan, 1300 rpm, 17 dBA
- Rear (exhaust) Cooling: 120 x 120 x 25 mm, 1300 rpm, 17 dBA
- Dimension 440 x 200 x 495 (mm)
- Security Lock Application
Only £55.99 inc VAT.
BUY NOW
Thermaltake VI1000BWS M9 Windowed Tower Case - Black (No PSU)
- Color Black
- Motherboard Tray
- 5.25" Drive Bay 9
- Expansion Slots 7
Only £59.98 inc VAT.
BUY NOWhttp://www.overclockers.co.uk/showproduct.php?prodid=CA-103-TT&groupid=701&catid=7&subcat=1479
BUY NOW
BUY NOW
- Color Black
- Motherboard Tray
- 5.25" Drive Bay 9
- Expansion Slots 7
BUY NOW
- Color Black
- Motherboard Tray
- 5.25" Drive Bay 9
- Expansion Slots 7
