Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
Hi guys, a little help would be much appreciated. My main rig, specs in siggy plus Sony Sata dvdrw, WD 320Gb AAKS sata ll hdd (Vista 64 bit) and a Seagate 7200.10 320Gb sata ll hdd (XP 32 bit) has been having some problems since Wednesday.
It started off taking longer and longer to boot and then when i go to shut down it goes into standby instead. I then have to press the power button on the case and it turns back on from standby and then shut's down properly. In Vista's problem reporting section there was an entry for the CPU which went something like high power features have been disabled on core 0 and the same for core 1. Last night it also would'nt recognise the dvdrw drive. This afternoon it refused to boot at all. It got to the IDE/Sata controller part of the post sequence and displayed a load of gobbledegook after IDE 2 which is the dvdrw drive.
I have tried clearing cmos, using one hdd at a time, changed the sata cables for brand new ones, changed the dvdrw, ran memtest for four hours with no faults, ran at stock speeds and it does'nt matter if i use Vista or XP, it has the same problems. I am thinking maybe the chipset on the motherboard has gone.
The rig has been running at 3.8Ghz for several months now as the gains with 4.5Ghz are minimal. For 3.8Ghz i use a 400fsb and the board needs no extra voltage for this so it's not a overvoltage problem and it certainly is'nt heat related. Nothing has been changed, it just started out of the blue. I would appreciate any suggestions/thoughts you may have. Thanks for taking the time to read this.
