11 Jul 2009 at 15:25 #2 Ben M Ben M Permabanned Joined 17 Nov 2007 Posts 10,278 Location Chester/ Bristol uni Uther said: http://www.overclockers.co.uk/viewcart.php[img][/QUOTE] sadly, it doesn't work like that. hit printscreen paste into paint crop it save it go to [url]http://tinypic.com/[/url] and upload it post the result here Click to expand...
11 Jul 2009 at 15:43 #3 Kennysevenfold Kennysevenfold Soldato Joined 9 Sep 2008 Posts 7,940 Location Glasgow Or just copy and paste the basket lol
11 Jul 2009 at 15:45 #4 Ben M Ben M Permabanned Joined 17 Nov 2007 Posts 10,278 Location Chester/ Bristol uni that always gives you the products listed twice, which is really annoying. and harder to read.
11 Jul 2009 at 16:05 #5 Kennysevenfold Kennysevenfold Soldato Joined 9 Sep 2008 Posts 7,940 Location Glasgow Ben M said: that always gives you the products listed twice, which is really annoying. and harder to read. Click to expand... How true Tis quicker though
11 Jul 2009 at 22:41 #6 Uther Uther Soldato OP Joined 16 Jun 2005 Posts 24,660 Location In the middle Hah! Thought I had deleted this message!
11 Jul 2009 at 22:43 #7 Uther Uther Soldato OP Joined 16 Jun 2005 Posts 24,660 Location In the middle Basically, this: Last edited: 11 Jul 2009
11 Jul 2009 at 22:59 #8 cmndr_andi cmndr_andi Soldato Joined 23 Apr 2009 Posts 11,973 Location Cheshire That combination will work well for a budget gaming system. If you are upgrading the system in your sig, i'd suggest getting a newer graphics card, such as this or this. Also, you may want to switch to this faster RAM.
11 Jul 2009 at 23:19 #9 Uther Uther Soldato OP Joined 16 Jun 2005 Posts 24,660 Location In the middle Would the Kingston HyperX make much difference over the corsair?
11 Jul 2009 at 23:22 #10 cmndr_andi cmndr_andi Soldato Joined 23 Apr 2009 Posts 11,973 Location Cheshire Not a massive difference, but it would run a bit faster. If you already have the corsair, keep it - its good stuff. But if you need to buy RAM, then the Kingston is a better bet and the same price.
11 Jul 2009 at 23:28 #11 Uther Uther Soldato OP Joined 16 Jun 2005 Posts 24,660 Location In the middle Thanks!
11 Jul 2009 at 23:38 #12 PermaBanned PermaBanned Soldato Joined 7 Jul 2009 Posts 16,234 Location Newcastle/Aberdeen I saw an Athlon II 245 for only £50, on a different site (*** Don't even hint it ***). That would be worth it.
12 Jul 2009 at 09:32 #13 Uther Uther Soldato OP Joined 16 Jun 2005 Posts 24,660 Location In the middle So,would it be worth looking at a athlon 250 cpu or a P11 550 over the 7850? There seems to be a confusing amount of AMD chips around now! Last edited: 12 Jul 2009
