Steer clear of UVred coolant and get red tubing.
Why do you say that? Was planning on getting Feser One UV Red lol
Yes indeed it isI will be using red coolant when I'm watercooling.
Be a right ***** if heaven forbid you had to upgrade to an NVIDIA card in the future lol![]()
If they did a similar design to this (colour wise) then i think it would still look great.
Yah mate UV red looks pink or orange. Primochill LRT UV red tubing is about the best you can get for quality red looking.
Yep. Would still look fine if the card was just black![]()
But its NVIDIA! The Green goblin!ATI fanboys nightmare!
OK, I will have a look into that. Thanks
Know of anywhere in the UK that stocks the tubing?
I know there's the P180 mini but that has some garish vents dotted on the door and top which make my eyes weep (no offence to any owners!!).
I have the P182 not P180 btw![]()
coolmiester that's one sexy build. Love the paint job
Amazing Work and great attention to detail in all your builds.
Bradley8988, any chance you could point me in the right direction over msn![]()
Hmmmm we just done a group buy from the states on another forum and a few guys got some in. Im not sure if anyone in the UK stock it. Whats ur msn.
Who said I was an ATI fanboy?![]()
System Specification:
Intel DX58SO Smackover Motherboard
Intel Core i7 965 Extreme Edition CPU
OCZ (3x2GB) DDR3 PC3-10666 Platinum Low-Voltage Triple Channel Memory
OCZ (2x60GB) Core Series V2 SATA II 2.5" SSDs
Zotac GeForce GTX 295 Infinity Series Graphics Cards
Cooler Master Real Power Pro 1,000 Watt Modular PSU
Watercooling Spec:
Custom made CPU & Chipset Block based on Danger Den MCP-Chipset Blocks
Zotac GTX 295 Infinity GPU Blocks
Hardware Labs X-Flow GTX360 Radiator (custom made)
Hardware Labs X-Flow GTX240 Radiator
Two Laing 18 Watt DDC Pumps
Two Dual Bay Reservoirs
Feser UV Red Liquid
Tygon 1/2in 3603 Hose
