No worries!
I didnt realise there were sub 20k ones out there![]()
You can some tidy fairly high mileage ones for around £14k.
No worries!
Don't pretend to know anything about M3's.![]()
I can confirm that it's still going strong at 145,000 with only a £23 PAS pipe needing replacing.![]()
Obviously the 330d will be smelly and sound like a Ice cream vanbut are there any other things i should be aware of?
smelly? mine only smells when an injector has gone..... which leads me to the next point..
turbo
6 injectors that will all go once one has (costly)
lower fuel pump
all the above are common problem points :]
Ive just always lusted after one but not sure the 10k premium is justifiable.
Ive been thinking about it and unless I track it, how much more is the CSL going to offer me over a standard M3 for road use?
Drive them both and you'll see how much more it offers, except in the 'goodies' dept - you may not even get a Radio/CD, but once you've heard the engine you'll understand why that option is unnecessary![]()
Do you guys know if you can fit the Alpha-N induction kit to the standard e46 easily?
Housey - I got my M3. Went for SMG in the end. Loaded with kit and has the AC Schnitzer exhaust which I believe was a factory fitted option. Sounds immense!
