13 Jul 2009 at 06:11 #1 Tefal Tefal Caporegime Joined 30 Jun 2007 Posts 68,867 Location Wales hey guys in windows 7 is there anyway to tile multiple windows (of the same type) automatically so they can all be seen at once? Thanks in advance
13 Jul 2009 at 08:24 #2 platinum87 platinum87 Soldato Joined 25 Nov 2007 Posts 5,581 Location London http://fird.kucing-kelabu.com/2009/01/guide-windows-7-tricks/
13 Jul 2009 at 11:06 #3 IAmATeaf IAmATeaf Soldato Joined 3 Apr 2007 Posts 7,296 Location South of the Watford Gap! You have to hold down the shift key when you right-click to see the tile options AFAIK.
14 Jul 2009 at 02:20 #4 Tefal Tefal Caporegime OP Joined 30 Jun 2007 Posts 68,867 Location Wales platinum87 said: http://fird.kucing-kelabu.com/2009/01/guide-windows-7-tricks/ Click to expand... dragging to the side doesn't work with windows that don't change size You have to hold down the shift key when you right-click to see the tile options AFAIK. You have to hold down the shift key when you right-click to see the tile options AFAIK. Click to expand... Ahh seems you have to have combine on in the taskbar options to be able to do it
14 Jul 2009 at 11:24 #5 IAmATeaf IAmATeaf Soldato Joined 3 Apr 2007 Posts 7,296 Location South of the Watford Gap! Well you could select the windows using the CTRL key then shift and right-click.
