Audi New Sensor? - Rain, lights...radar..something...?
13 Jan 2004
At least that's what I thought as I creeped up the outside lane closer to it..and closer...and closer....ah.. I see now :D
FORE! :eek:
He probably hasn't noticed yet :D
He will, and then... "FFFFFFFFFFFFFUUUUUUUUUUU--"
Edit: What kind of dodgy numberplate is that?
The sunlight reflection off the top left curvature matches the rest of the image and the "top" of the ball appears above the whitened glass around it.
Need some image detectives! :p
A windscreen might do that but a rear window (unless that TT is diff to most cars) don't have laminated glass, so a ball wouldn't stick in it like that the whole window would shatter.
Are you qualified to say that it would or would not?, too many variables.
I'd say its possible.
If the window isn't laminated it can't hold itself together, thats a cold hard fact, its nothing about being qualified or not its about knowing that non laminated glass won't stay together, the windscreen stays together due to the fact the layer of plastic holds the glass in place.
Googled around at some of these stickers, and some of them are shockingly realistic.
The only reason I doubt it is one is the rear window is angled and it was clearly "bumped" upwards, an affect a stick could not have unless viewed head on?
If the window isn't laminated it can't hold itself together, thats a cold hard face, its nothing about being qualified or not its about knowing that non laminated glass won't stay together, the windscreen stays together due to the fact the layer of plastic holds the glass in place.
So you're saying it's impossilble to have an object break through/into the glass without the whole screen smashing?
Oh how wrong are you.
