Question regarding work breaks.
11 Feb 2009
Barnsley, South Yorkshire
I work in a chippy and we are not allowed to have a break unless we work over 6 hours straight, then are we allowed a 30 minute unpaid break.
This means that I have to work from 9-2:30 without a break causing me to become rather dizzy and faint from doing so.
Can anyone shed any light on this?
On tuesday I work from 9-2:30 then from 4:30-10:30 ish.
http://www.direct.gov.uk/en/Employment/Employees/WorkingHoursAndTimeOff/DG_10029451
Types of breaks
You will normally have a variety of different breaks from work. These can be broken down into three types:
'rest breaks' - lunch breaks, tea breaks and other short breaks during the day
'daily rest' - the break between finishing one day's work and starting the next (for most people this is overnight between week days)
'weekly rest' - whole days when you don't come into work (for many people this will be the weekend)
The second and third types of break are almost never paid unless you have to remain 'on call', meaning you are available to work. The first type is often paid, but doesn't have to be unless your contract says so.
Contracts of employment How much break time do you get?
The amount of break time you get is usually agreed with your employer. It may be written down somewhere (eg in your contract of employment) or might just be part of your employer's standard practice.
Your employer must give you at least the rest breaks required by the Working Time Regulations. They must also ensure that your health and safety is not put at risk. This means that your employer might have to give you more than the amount set out in the regulations, if this reduces a health and safety risk.
Employers' health and safety responsibilities Young workers
If you are under 18 but over 'school leaving age', you are classed as a young worker and have different break allowances to adult workers. You are under school leaving age until the end of summer term of the school year in which you turn 16.
Young workers and working hours (young people section) Rest breaks - a break during your working day
If you are an adult worker (that is, over 18), you will normally have the right to a 20 minute rest break if you are expected to work for more than six hours at a stretch.
A lunch or coffee break can count as your rest break. Additional breaks might be given by your contract of employment. There is no statutory right to 'smoking breaks'.
The requirements are:
the break must be in one block
it cannot be taken off one end of the working day - it must be somewhere in the middle
you are allowed to spend it away from the place on your employer's premises where you work
your employer can say when the break must be taken, as long as it meets these conditions
Daily rest - a break between working days
If you are an adult worker you have the right to a break of at least 11 hours between working days. This means as an adult worker, if you finish work at 8.00 pm on Monday you should not start work until 7.00 am on Tuesday.
Weekly rest - the 'weekend'
If you are an adult worker you have the right to an uninterrupted 24 hours clear of work each week or an uninterrupted 48 hours clear each fortnight.
Exceptions to the regulations
Your working week is not covered by the Working Time Regulations if you work in the following areas:
jobs where you can choose freely how long you will work (such as a managing executive)
the armed forces, emergency services and police are excluded in some circumstances
domestic servants in private houses
The rights to breaks apply differently to you if:
you have to travel a long distance from your home to get to work
you constantly work in different places making it difficult to work to a set pattern
you are doing security or surveillance-based work
you are working in an industry with busy peak periods, like agriculture, retail or tourism
there is an emergency or risk of an accident
the job needs round-the-clock staffing (such as hospital work)
you are employed in the rail industry and you work on board trains or your activities are irregular or linked to seeing that trains run on time
In these cases, instead of getting normal breaks, you are entitled to 'compensatory rest'. This is rest taken later, ideally during the same or following working day. The principle is that everyone gets a minimum 90 hours rest a week on average. This is the total of your entitlement to daily and weekly rest periods, although some rest may come slightly later than normal.
Mobile workers
If you work in air, road or sea transport you are what is known as a 'mobile worker' for the purposes of the Working Time Regulations. This means that you are excluded from the usual rest break entitlements. Instead, you are entitled to ‘adequate rest’. This is a regular rest period long enough to make sure that tiredness, or other safety issues, do not cause you to injure yourself or anyone around you.
For more information about working hours for drivers and crew in heavy goods vehicles (HGVs) and passenger service vehicle (PSV) drivers, contact the Vehicle and Operator Standards Agency (VOSA) on 08706 060 440.
What breaks am I entitled to under the working time regulations?
The Working Time Regulations 1998[1] state the following provision for rest breaks at work and time off:
Rest breaks at work
A worker is entitled to an uninterrupted break of 20 minutes when daily working time is more than six hours. It should be a break in working time and should not be taken either at the start, or at the end, of a working day.
Daily rest
Under the Working Time Regulations 1998, regulation 10, a worker is entitled to a rest period of 11 consecutive hours rest in each 24 hour period during which he works for his employer.
However, there are a number of special circumstances in which the entitlement to rest periods does not apply, for example, where the activities involve a need for continuity of service or production or where there is a foreseeable surge of activity. Also, if a shift worker changes shift, it may not be possible for them to take their full rest entitlement before starting the new pattern of work. In such a case the entitlement to daily and weekly rest does not apply.
back to top
Weekly rest
An adult worker is also entitled to one day off a week; this can be averaged over 2 weeks.
Young or adolescent workers
If a young worker is required to work more than four and a half-hours at a time, then they are entitled to a break of 30 minutes. A young worker is also entitled to twelve uninterrupted hours in each 24-hour period in which they work. Both these entitlements can only be altered or excluded in exceptional circumstances. Young workers are also entitled to 2 days off each week and this cannot be averaged over 2 weeks.
There is a free guidance produced by the DTI (Department of Trade and Industry), which can provide more information.
http://www.hse.gov.uk/contact/faqs/workingtime.htm
6 hours straight would take you to 3:00 pm...so you're breaking his rules but he sounds like a ****.
why you're feeling dizzy is what you should be concerned about though.
you wont be doing anything a lot of the time which surely counts as a break? where as some jobs your constantly working the whole time not standing around waiting for customers
