Hey guys. Situation I'm faced with is the stepmothers computer. Its running windows xp, with four user accounts, one for each member of the family. 2.4ghz pentium 4, 1gb ddr1. I'm not trying to upgrade that again, it's a dell and shredded my fingers putting more ram in. I'm trying to persuade her to spot £500 on replacing it already, but in the meantime it would be good to get the current machine running nicely.
So far its running spybot and avg, passes scans of either cleanly. Zone alarm free. However the system is a state, hideous mix of uninstalled and part uninstalled programs. Really silly numbers of shortcuts that don't go anywhere. The solution I'd use myself is reformat and install from scratch, but I *really* don't want to kill any bookmarks, document settings, files etc.
First option. Back up everything and reinstall. I like this one, but don't know where to find application settings. All files are probably in my documents, but where does office 2003 save settings to? Similarly firefox, and possibly some other programs. Any analogue of /home in windows? Wonderfully Ive got the missus saving everything to a second partition, with the desktop and so forth invisibly linked to it. No such luck with the mother.
Second option. Clean the current install as best I can. Something tells me this will be more time consuming and leave a worse end result, but its only current option if I can't back up everything.
So what should I do? Its been a while since I used windows all the time, but I'm competant. I never learnt to back up settings, as I just save data to a different drive and reinstall at will, normally from a slipstreamed nlite. Even now I don't have /home on a seperate partition.
Advice welcomed.
p.s. Its windows xp, and staying that way. I could retrain her to use openoffice and ubuntu swifter than I could change her to using windows 7, but this doesn't mean either option is a practical one. I do wonder if she'd notice me changing it to kde without telling her, but better safe than sorry
Advice welcomed.
