- 13 Jul 2009
Been having difficulty tracking down OCUK staff for questions in regards to this bundle. So registered on the forum to ask a few Q's. For those that have the bundle I wondered if you could answer a few questions?
1) What volts did OCUK put in your chip? What VID did your chip come with?
2) Do you know how it is tested? Prime for 8 hours? Have you personally tested prime at the rated speed for 8 hours+?
3) What temps are you reaching idle/fully loaded?
4) Did any of you have concerns on the HSF fitting in your case and if so did they offer you an alternative at a discount as part of the bundle still? Or you pay the extra on top of the normal HSF?
5) How long did your package take to arrive?
6) If you have any general pros & cons about the bundle can you just list them.
Im tempted with the bundle as the offer price (assuming it continues at around the mark it currently is) is more or less the same price as the individual parts but they go through the labour of the BIOS for you. You then just need to fine tweak it a bit when putting in your computer. Sounds good to me.
Cheers
JonnyG
Cheers
JonnyG
