Cost To Fit New Suspension
1 Feb 2006
Reading
Just wondering what a ball park figure would be for a garage to fit an aftermarket suspension.
Cost to change just springs?
Cost to change both springs and dampers?
Cheers.
What car?
If its something like my Mark I golf then a day would see all four corners done for both springs and dampers.
Something like a M3 I guess a few days? :p
Just do it yourself its easy :p I fitted sachs coilovers to my vx220 in about 3 hours
What car is it?
I think if I was doing it as a side job for someone I'd do it for about £100 on your average McPherson strut equipped car. At a garage - no idea.
I've swapped e36 M3 from standard out to race legs in less than a day. But then race suspension is my thing :D
lol!
I was talking to a mechanic a while back who said it took him 2 days to take off and replace just the front suspension on a Audi S3.
I had my Golfs front totally apart and back together in 3 hours once :p
Is there much difference in price between fitting just springs as opposed to shocks and springs?
Not normally - the dampers generally have to come off to do the springs anyway so it shouldn't really cost any more for labour.
