my Asus 4890 seems quite stable @ 995/1100 - with 1.41volts
temps are quite low about 66C max under ATI tool after 10 mins, and above 75-80C on furmark
but - even after about 20 seconds, 2 of the VRM temps while running furmark go to 106C !
is the answer just not to run furmark ? and that they'll never get this hot in normal usage? or should I lower the volts on the core
thanks, MArk.
thanks, MArk.
