- 11 Apr 2009
Hi guys,
First, my system:
E7400 2.8 @ 3.6GHz
4GB (2x2GB) PC8500 RAM
512MB 9800GTX+
Asus P5KPL-AM Motherboard
Xigmatek cooler + Noctua case fan
Basically I'm now stuck with this overclock. This motherboard's FSB is rated at 1600MHz but I just can't get it there. The bad thing about this board is that the FSB:RAM ratio cannot be changed, it's changed automatically depending on other settings. My current settings are this:
Multiplier: 10.5
Vcore: 1.392
RAM voltage: 2.1
Bus speed: 344MHz
Rated FSB: 1376MHz
I've attached pictures of cpuz and the BIOS. I cannot get the bus speed above 344. I've tried 345 but get a no POST, I've tried different combinations of bus speed and multiplier, different RAM speeds, but it always ends in a no POST. I'm dying to get this thing up to 4GHz, but I don't know the magic combination that might do it. Does anyone have any ideas?! I've attached pictures of all the info you might need but if you need any more then please ask!
Thanks.
First, my system:
E7400 2.8 @ 3.6GHz
512MB 9800GTX+
Multiplier: 10.5
Vcore: 1.392
RAM voltage: 2.1
Bus speed: 344MHz
Rated FSB: 1376MHz
Thanks.
