Tree Sap of fail
28 Sep 2008
Britain
Gents,
When I was in France, the car got a fair bit of abuse from Pine Tree sap. It's like the stickiest glue / adhesive i've ever seen.
Warm water = FAIL
Washing up liquid = FAIL
Clay bar = FAIL
AG Tar remover = FAIL
Household adhesive remover = FAIL
before I kill it with steel wool and then rotary out the scratches, is there anything else on the planet I can use to at least break it down if not fully remove?
Hmm, reading around, its more likely to be Honeydew from the bottoms of insects that live in the trees.
Sonus Grey clay bar is what i have used in the past, but this leaves marring so may need a going over with a polish afterwoods.
Use TFR and let it really soak in, it will strip your wax off tho.
Parents house has about 8 of the massive things over the drive. Have lived with this for 25 years !!!
Solution
1.) Use an old credit / store card to scrape off as much of the dried resin as possible.
2.) White spirit on rag and rub.
3.) Wash area thoroughly, then proceed to detail.
Have done this on the 6 cars we have at the house for donkeys years, no other method has come close to the speed and reliability. Actually went and used this method on my Sunny a few weeks ago and it still works a treat.
Don't laugh but I have had this problem in the past (lime tree iirc) and got it off with....wait for it..................
Johnsons baby wipes. :o
Don't ask - I just know it works.
Someone suggested vegetable oil and it's basically the same principle as the baby wipes - the wipes I guess are sprayed in johnsons baby oil?
Fire. Fire fixes everything.
/pyro
Disclaimer: This may destroy you, your car, and anything nearby.
Gents,
Warm water = FAIL
Clay bar = FAIL
sounds like you have just been a bit namby pamby in your attempts and not given it some propper elbow grease.
I have this amazing product for my bike helmet for removing bugs and squashed crap - it disolves it effortlessly. Go to halfrauds or somewhere like that and look for bike bug cleaner or something of that ilk. It won't damage the paintwork either. :)
