Bright sparks come up with Frickin' Laser combustion
mrk
mrk
Man of Honour
18 Oct 2002
Uranus hehehe
Pun intended :p
autoblog said:
In a breakthrough that may make vehicle starting issues due to fouled plugs or inclement weather a thing of the past, engineers at Ford have reportedly teamed with scientists at Liverpool University to develop a laser beam ignition system to replace ye olde spark plug. The researchers claim their technology is more efficient, more reliable, and it will enable vehicles to start easier in extreme temperatures and damp climates.
Unlike traditional spark plugs (invented way back in 1839 by Edmond Berger), laser light may be split into multiple beams distributing ignition points within the cylinders – not just at the tip of the plug. This not only aids combustion, it also lowers emissions during cold starts. Researchers also point out that the lasers use less energy than their spark plug counterparts, eliminate wear items and wires (fiber optics will carry the laser beam to the cylinders), and improve fuel burn by "watching" ignition from within the combustion chamber and sending messages back to the ECU to adjust fuel mixtures, timing, and ignition.
Ford is expected to introduce the technology in its top models within the next few years, and then make it more widely available. Thanks to everyone for the tips!
[Source]
Surely they will need to be rather powerful to ignite Petrol vapour?
Probably not too much, remember you don't need as much energy when it is under compression.
Interesting to see this in person and see the potential gains. More complete combustion is always a good thing.
i suppose something had to replace the spark plug eventually
all this new fangled technology and we're still going round lighting fuel and air with a spark plug invented 170 years ago !
The mains concern is if its cheaper, thats all that really matters, spark plugs at the moment represent close to zero cost of running a car.
Already got that.
It will be interesting to see what it's pitfalls are, because it will not be flawless by any means. I can see it being very sensitive to carbon deposits, if the engine runs wrong because of any sensors it may now just stop altogether.
Yeah more efficient combustion = less fuel burnt and more power, and regarding the section about the ECU managed reader to optimise the LASER power, something like this could be new remapping methods perhaps? increase laser power etc?
No doubt the new advertising slogan for a Ford will be along the lines of..
Ford... now with added pew pew!
:D
Yes, it does, meaning that more power can be delivered for more of the power stroke. My car already does this.
I guess the laser system can change from multiple shot to single shot on demand, does the t spark do that or is that a fixed system?
