Best video card for e5200 overclocked bundle
30 Jun 2009
Hi,
I've just bought the overclocked e5200 bundle from overclockers and was wondering whats the best graphics card to get for this setup without having any CPU/MOB bottleneck probs. I have a 700W OCZ PSU.
Cheers.
I play mainly WOW at 1680 x 1050 res but would like to play it with max settings for effects etc. With a decent card I would also give Crysis a go
I have a budget of £150.
I use this bundle for my gaming pc at work with the same power supply i found the 4870x2 very good even with this cpu i also play wow a lot myself i can run it all maxed out at 60+fps at 1920x1080 but if your mainly going to run wow you will see a better frame rates from the 4890 because wow uses an old 3d engine and only makes use of 1 of my 2 Gpu's so go for a 4890 (it should be faster then a 280gtx) only card on the market quicker (mybe 5-8 fps more) would be the 285gtx i say gogo for the sexy XFX4890 it will run everything out on the market and is within your budget.
