They're fine, but you'll need a package with Sky TV to get it. Alternatively go through UKOnline, the consumer arm of Easynet, the ISP Sky own and use to provide their broadband service.Sky Unlimited (16MB down/1.3MB up) seems like my only well known LLU option. How are they as an ISP?
That's right, Sky Unlimited is the only unlimited broadband service they offer, and it's only available on exchanges they've unbundled.Is the service not unlimited when not using a LLU connection
No, you can get the same services via UKOnline, they just charge more and make you buy a Netgear DG834GT. But then compared to your other options they may still be good value. Your exchange info shows it's been enabled for Wholesale Broadband Connect, which means ADSL2+ services via BT Wholesale from ISPs who've chosen to offer them, but there you've got a choice of usage allowances instead of an unlimited service.and are you saying I will only get a non-LLU connection if I don't buy a sky TV package?
Yes it will.I'm happy to go with Sky unlimited if it means that it will be on the LLU service, all I need to know is will this happen with this offer:
http://www.sky.com/portal/site/skycom/skyproducts/broadband/pricesandoptions/max
Is there any reason not to go with Tiscali?.
That's bull. Are you moving into flats by any chance?Our letting agents also report a poor sky signal in the area![]()
