Other things being equal, the faster-spinning a drive, the lower the seek times. So I would expect a 15k SAS/SCSI drive to beat out a velociraptor, regardless of firmware, but different firmware optimisations could make a bigger difference than I am allowing for..
Just bought a 500GB Seagate for use as a boot drive, going to apply this to it. Sure I'm only going to get around 150GB of the 500GB storage, but that 150GB is faster than the 150GB Velociraptor and much much cheaper
http://www.techwarelabs.com/seagate_1-5tb-mod/all/1/
wow that link is really interesting..
SO how does it actually speed up the drive? does it jsut use the faster part o teh drive? or is there something else to it?
Have you tried doing different comparisons. Down to like 50GB? 2 in raid and you could potential get vertex speeds but many many times the capacity.
Can you do this with any drives or just that one?
Any chance you can do like 5 different Size tests? so we can see a comparison and if there is a sweet spot. All thought that would take a while, so understand if you can't.
Does this work on any seagate drive then? Doesnt have to be the 1.5TB that is used in the review?
Does anyone here actually have one of those Seagate 15k RPM drives though?
I dont get this stroking business. Surely if you just partition your drive correctly and have Windows sitting on the first partition, at the fastest part of the disk, everything you do on that partition will be fast. Its only in benchmarks (averages) that this mod would actually make a difference surely.
