Php quickie
fez
fez
Caporegime
22 Aug 2008
Tunbridge Wells
Hi guys,
Just a quick question for a php guru. I have created a gallery cms and part of this is creating some thumbnails and medium images which are generated from the master image the user uploads.
It all works fine using imagejpeg(myimage, target save location) however I want to make sure that the program only continues into creating the other images if the previous one has worked. I dont want to enter a DB record if one of the image creations has failed.
So how to I check the success of the imagejpeg() function.
Thanks
Hi guys,
Thanks
There's an example on the php site in the comments section for that function http://www.php.net/manual/en/function.imagejpeg.php#89866 - towards the bottom of his comment.
