Gaming Monitor Decision? ASUS OR SAMSUNG
24 Sep 2008
Hi Hi,
I am looking to purchase a gaming monitor for competitive use. The two models I found are the Asus PG221 and the Samsung SM 2233RZ.
I do not know which model to choose and need some advise. I noticed that the Asus monitor has a low response time of 2ms, and the Samsung has a 5ms. Does this make the Asus a far superior monitor or does it not make much difference?
My budget is £300.
Thanks for all your advise :)
Cheers
I think the SM2443BW has a similar (if not the same) panel and a more adjustable stand. Simpler design though...
I have just had a look at the contrast ratios and noticed that the Asus PG221 has 2000:1. Does this make it a bad monitor. Most of the new monitors have 20,000:1.
Thanks
