My point is that I am using Windows 7 RC1 - Build 7100 64 Bit already.
My last PC died, so I decided to use Windows 7 as it supports more then 4gb of ram.
I imagine I am not alone amongst people doing a new build.
When the final version comes out in October. Lets say I buy it.
There is no upgrade.
So how can you get a Windows 7 RC1 system backup to Windows 7 Final Build with hundreds of programs in under 3 hours?
Isn't the point that you would need to reinstall all the programs, because otherwise the dll hooks (or whatever they use) wouldn't be correct?
Any 'image' (and I have that because its backed up to a Windows Home Server) is going to be of the RC1 installs, and not the Final Build. So surely, you would need to reinstall all the programs, settings etc etc???
(Though this point on the Wiki page leads me to think one may be coming in Jan 2010. In which case I would just wait until then, as there is really no problem with the RC1 version.
Actually, come to think of it, wasn't the RTM version relesaed to Technet and MSDN on the 15th July?
Can anyone comment on how the final version compares to RC1?
Upgrades to Windows 7 E will require a clean install until upgrade versions are released in Jan 2010[citation needed] due to ongoing testing, as Windows Vista contains Internet Explorer, which would have to be removed by the upgrade procedure.
http://en.wikipedia.org/wiki/Windows_7_editions#Comparison_chart
