Thor's Hammer, Cooling & The UD5
30 Jul 2007
Lincolnshire
Hey,
Was looking at a bit later this year in upgrading my PC, just the base parts; motherboard, processor and RAM from my Q6600-based setup to an i7 920 setup! :D
Decided on these:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - Retail
£205.99
Gigabyte GA-EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
£203.99
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel (PVT36G1600LLK)
£75.99
Total: £485.97
Unless you guys can recommend anything better ^^ ? :)
Now cooling-wise, I want a good cooler for the 920 of course.. I was looking and thought the Xigmatek Thor's Hammer looked a good cooler (well, heatsink cooler?!) and I'm sure you can fit a 120mm fan on it - correct? Was just wondering if this heatsink is the right choice? If so, what would be the best 120mm fan for it?
Cheers! :cool:
Josh
Lots of people recommend the Noctua 120mm Vortex fans, they are quite pricey, but they are supposed to be really good, and quiet to...
I personally don't like the color scheme, but that's just my opinion...
Scythe S-Flex fans are meant to be quite good also...
If you aren't looking to spend that much on a fan then I would suggest one of these, at £6.89 you can't complain, and I am sure it would get the job done quite nicely...
Haha, someone who shares the exact sentiments as myself. I know a lot of people and a few friends I personally know all recommend that Noctua fan, but I just hatehatehate the ugly beige colour scheme it has going, it's awful.. could have made a popular fan at least a nice premium colour like black or something.. Hmph! That is the reason I won't ever buy one. :p
The Scythe S-FLEX and Xilence Red Wing fans you referred too though; despite the Scythe being £12.64, it outputs 63.7 CFM of air flow at 28 dBa.. However the Red Wing priced at £6.89 outputs 68 CFM of air flow at 21.2 dBa.. Or am I missing something blindingly obvious here? :eek:
its a typing mistake the red wing outputs max 44cfm,
i too dont like the colour scheme on the noctua, but the Xigmatek series have some great looking fans with high cfm too (62cfm)
Would that be the Xigmatek XLF-F1253? :)
cfm mean nothing without a static pressure reading
db mean nothing without a distance between source and detector
So essentially the specifications quoted are best ignored, go with people who have tested them instead. Scythe s-flex will do you proud, Ive got around a dozen of the 1600rpm ones.
I'm going to use UD5, 920 and corsair dominator when/if I move to i7, with a TRUE as well. This is only because the dominator is easily watercooled however.
Nice spec :)
Someone posted on these forums a while ago stating that the color of the Noctuas are the same color as the plastic used for making prosthetic limbs!!! :D
That being said though, they are supposed to be excellent performing fans, and really quiet to...
I just bought one of these fans from the Members Market for £6, I will be strapping it to my TRUE once I get the LGA1366 Bolt Thru Kit... I saw a picture of this fan fitted to a TRUE on here yesterday and thought that it looked really cool...
Does it only fit 1x 120mm fan? I know a few heatsinks have 2x 120mm fans attached either side, both exhausting hot air through the heatsink and enabling it to escape quicker through the rear case exhaust fans?
