Can photgraphing lasers damage your camera sensor?
4 Jan 2004
¯\_(ツ)_/¯
I ask because it can damage your eyes... I've got the special glasses, but I was hoping to try some long exposure shots of a 100mW green laser.
Is it safe to do so?
It will overexpose tbh if you do long exposures
do you want to shine it on the sensor or in clubs?
I have shot power pulse lasers on a 350D before for a project. The power delivered was around 0.35J and it needed NDs.
That was with a green laser btw.
What exactly do you want to do with a continuous laser?
sid
sid
I wasn't planning on shining in the sensor, it's not a club type laser, it's just a small handheld laser and I wanted to try some of those "painting with light" type photo's with a laser. :)
I don't have any filters, but I think I may have some ND gel which I can try and experiment with...
oh if you are not shining it on the sensor then theres nothing to worry about
should be fine in my opinion, your sensor is probably a little more resiliant than the back of your eyeball :)
Yep, I guess there are UV and IR filters on most DSLR's, I was concerned as I got a leaflet with my laser thing saying it could make you blind if you didn't wear the glasses so I thought it would be better to ask first as D60'd aren't cheap! :eek:
I was more worried about the laser it reflecting off something and going in the sensor... ;)
lol, oh my god..
:confused:
DW mikehunt I'd be more worried about the laser going into your eyes rather than the camera.
As long as you don't focus it on the sensor, it should be ok.
sid
