24 Jul 2009 at 00:02 #1 manjuice manjuice Associate Joined 7 Mar 2007 Posts 1,244 Just making sure if it is a RJ11 to RJ11 cable I need to allow my router to be positioned further away from the socket. Also is it true a longer cable will reduce connection speed and should I go for an unbranded cable or go with branded one like Belkin?
24 Jul 2009 at 00:21 #2 Sin_Chase Sin_Chase Soldato Joined 13 Jan 2004 Posts 21,254 Don't spend the earth on an RJ11 cable. Increased length will reduce your line quality marginally but nothing major. Don't put a ridiculously over sized cable in for the length you need But yes, you need a RJ11-RJ11 cable to move your modem further away from the socket.
24 Jul 2009 at 00:24 #3 manjuice manjuice Associate OP Joined 7 Mar 2007 Posts 1,244 What if I leave the router near the BT socket and buy a cat5e cable instead. Will I notice any speed decrease?
24 Jul 2009 at 08:40 #5 snakefood snakefood Associate Joined 18 Jun 2009 Posts 607 Location Luton The twisted pairs of cable inside are the same, so you will get the same quality. Just make sure your cables aren't kinked, and you should be fine.
24 Jul 2009 at 08:45 #6 Nick1881 Nick1881 Soldato Joined 4 Feb 2007 Posts 9,899 Location Nuneaton, UK tchan_4 said: What if I leave the router near the BT socket and buy a cat5e cable instead. Will I notice any speed decrease? Click to expand... This option will keep your speed as it is now. Its always better to have a longer network cable, your router is best left close to the socket.
24 Jul 2009 at 12:16 #7 manjuice manjuice Associate OP Joined 7 Mar 2007 Posts 1,244 Is it true a high quality rj11 cable will give me better speed or is the one supplied by O2 suffice?
24 Jul 2009 at 12:28 #8 tolien tolien Caporegime Joined 16 May 2003 Posts 25,367 Location ::1 As long as the cable short and decent quality it'll be alright. You don't need to spend ridiculous sums of money on cables.
24 Jul 2009 at 13:44 #9 gillywibble gillywibble Caporegime Joined 28 Jun 2007 Posts 52,812 Location Tamworth, UK tchan_4 said: Is it true a high quality rj11 cable will give me better speed Click to expand... I got an extra 200 kbps.
24 Jul 2009 at 13:50 #10 manjuice manjuice Associate OP Joined 7 Mar 2007 Posts 1,244 gillywibble said: I got an extra 200 kbps. Click to expand... What cable did you get?
24 Jul 2009 at 13:58 #11 gillywibble gillywibble Caporegime Joined 28 Jun 2007 Posts 52,812 Location Tamworth, UK tchan_4 said: What cable did you get? Click to expand... I got a 'Pro+' one with an XTE-2005 Faceplate. I won't link as they may be a competitor, but if you Google 'XTE-2005 Faceplate', it's the first result. They do longer cables as well.
