Best way to pull Twitter, Last.FM and Flickr feeds onto my website.
20 Nov 2002
Barnsley
Hi,
I'm just setting up my portfolio website after finishing uni and am wanting to put my recent tweets, songs and photos on there.
What's the best way to pull this information from the respective sites and display it on my own?
Would this be possible with jQuery?
Cheers for any help :)
Have a look at this. I know the vid is called Designing for Wordpress, but the techniques used in there for the Flickr/Twitter stuff aren't Wordpress specific. Hope this helps!
Not sure about Last.fm - maybe something similar exists for that?
Depends if you're running your website on a CMS or just standalone and looking for pre-built scripts.
I have a lifestream on the footer of my website with a mixture of Expression Engine plugins and non EE.
Twitter has instructions on their website, so does Last.FM but Flickr you might have to google :)
Cheers for the info thus far!
I'm using Wordpress as my CMS and I'm also wanting the data to be displayed in the footer of my site.
I did search for plug-ins but I was under the impression it could be done a lot more simply with a few lines of code.
For twitter I'd use http://twitter.com/badges
Easy enough, follow the onscreen instructions and at the end gives you some HTML code to paste
For Flickr I'd use http://flickrslidr.com/
Just follow the instructions on screen, real simple set-up
LastFM feed for Wordpress, cant find that much info on it tbh:
http://wordpress.org/extend/plugins/lastfm-rps/
Nice one, I managed to get Last.FM and Twitter working with these :) Probably work on Flickr tomorrow.
On a side note, does anyone know of a good jQuery image slider plug-in for WP? I'm wanting to display 3-5 select projects on my home page. I've tried vSlider but for some reason I can't get it working, it just sticks on the first image :(
Anyone? :)
